Brake bleeding
I recommend the power bleeder. It puts pressure on the fluid in the reservoir, which allows you to just twist the bleeder valves and let it stream out.
Since you both live on Long Island, maybe you split the cost of one and bleed together.
I did this recently with both the braking and clutch hydraulic system. Super Blue, baby. My 9 year old daughter had fun stomping on the brake pedal and pretending to drive.
Much easier than I thought with two people, but that Motive power bleeder looks awesome and makes a time consuming two person job into a short one person job.
Huh, you should do the brake pedal test first, before bleeding, to make sure it's not the Master cylinder and/or slave going!
I kinda have a slick spot under my pedals...it's pouring down rain right now, guess what I'M NOT GOING TO DO! Right, no driving tonight!
- Julie
- Julie
ATE Type 200 Gold brake fluid is the same as Super Blue, just without the blue coloring. A neat trick when you flush the fluid is to alternate between the two each time you flush -- when you see the color starting to change at each bleed connection, you know you've pushed the old stuff out!
Alright i am likley bleeding my brakes this saturday depending on the weather. I have read alot of problems with the bleeder screws stripping and being a pain to get off...etc. Is it worth while to just replace all four screws?
I've always just used the box end of a 6 point wrench on mine, never use the open end of the wrench to break it loose. Yeah, they can round off easy enough.
And I do love that motive bleeder after using it just a couple of times!
I might have to try out that gold/blue alternating fluid changes, sounds pretty slick!
When bleeding your brake I was told to start with the futherst wheel from the resovoir and work your way to the closet wheel to the resovoir. So, your right rear passanger tire should be first, second should be your left rear then your front right and finally your driver front left. Reno
And don't forget to get the slave cylinder last! It took me about 20 minutes to do that one climbing under the car and getting the right size wrench and wiggling in and out a couple of times. Gets that last bit of the old stuff out. Since you're there, you might as well.
Love that power bleeder too.....took me under two hours from start to the finish of cleanup and with only 2 jackstands and one jack, I was up on one side, down, up on the other then down, etc.
Motive pressure bleeder is key as others have said! Makes the job 10 times easier and you dont have to worry about pushing the brake pedal down too far and ruining a master cylinder!
You want to start from the farthest bleeder from the master cylinder and work your way in.
If you need a hand let me know, its a quick job.
