Wheres the fuel filter?
I did a search and after looking through 5 results pages of info, i cant find it. i knwo its definately been covered before... just need someone to quick let me know and ill even delete teh post if it bugs people. :P
so wheres teh fuel filter located exactly? Difficult to get to?
After finding your car didnt have an air filter are you making sure it now has a fuel filter??? Anyway, the fuel filters on the 924S(should be the same) are on the passenger side of the car just inside of the wheel well. If you note the fuel tank above the tranny follow the lines from the tank towards the front of the car. You'll see it! Its pretty easy access...
Good Luck, hope you find one there
-Erich
-Erich
i dont understand why anyone should be scared of posting a question now. i am a very busy person and i dont have alot of time to shuffle through old posts. well maybe sometimes i do. sorry about stealing your post. i just want to say that you can post the most asked question if you want, especially since your a member
jaibeiber, when you have your hood open, and you are facing the passenger compartment, it's in front of the driver's side, down in front of the fire wall, if I'm not mistaken, a canister looking device.
Also, check www.clarks-garage.com
I've found them to be very helpful! You will find it, don't worry.
- Julie
- Julie
- Julie
- Julie
Erich
The fuel filter on my 968 is where Erich said. There also is a smaller canister shaped device like Julie mentions where she said to look. I forget what that one is called but I have seen it labeled before. I have a new fuel filter to swap in so I have a positive ID on the fuel filter.
Not that I care about you posting here, but the search tool is usually a lot faster than posting. You just have to refine your searches a little. I did a search for location fuel filter and came up with https://rennlist.com/forums/showthre...on+fuel+filter
