1989 Euro spec manual swap question
Hello, I'm new to this forum and don't own a 944 yet. I just found a 1989 Euro spec 944. But its an autotragic. I've read enough to be a little confused about what transmissions will swap into which model and year of car. I need to swap in only type 016J and code ASG or ASH for LSD transaxles. Plus swap the ecu and all the other goodies, pedals, linkage, shifter etc etc . I assume the chances of finding the right type and code is pretty slim and probably a bit of a fools errand? And better to just find a manual in the first place? Any input appreciated . Thx
I would just wait and find a manual. You could swap it in theory, but it would be a REAL pain. If memory serves me correctly, the exhaust setup is different between an automatic and manual, not to mention you'll have to add/replace clutch, clutch pedal, master cylinder, shifter, shift linkage, etc. etc. and of course the transmission itself. Sometimes I'm tempted to jump the gun on a car, I've been there before, but just be patient my friend, wait for a manual.
Thx for the reply and advise. I kind of know all this I just thought I would ask to see opinions. I work on 80s BMWs and doing a 5spd swap isn't that big of a deal. Its basically the same on the 944, aside from the transaxle location and the coding on the trannies, plus ecu. Engine bay looks tighter. Very sound advice, many thx. I'm off to look at this Euro which I see has has a higher compression engine, 163 HP . Interesting
