Strange oil pressure gauge problem
So I finally got my car back together today, an 83' and something ive never seen or can find anything about is happening with my oil pressure gauge. Now for reference ive had the car hooked up to a mechanical oil pressure tester and it reads a healthy 4.5 to 5 bar pressure at cold, so I know that I am in fact getting good oil pressure, however when I took the sending unit back up it sticks at 1 bar, no lower no higher, and subsequently the oil light in the dash comes on. As I said before the mechanical gauge reads a healthy 4.5 to 5 bar at cold so I'm know I'm getting good pressure, but being a fresh rebuild I need that peace of mind of having a readout while I get through this break in period. Thanks
A quick test is to remove the sensor, reconnect the leads then use shop air at the small sensor orifice. Set your shop air regulator at 50 psi. Have someone watch the gage for change. Should see > 3 bar.
Best of luck
Best of luck
