Door Card Hole Question
This is probably a dumb question, but as I'm re-covering my interior door panels this round hole next to the speaker opening has me curious. Does it serve any purpose? I am fiberglassing and coating the door cards in epoxy resin (you can see that I've already covered the speaker opening), so is there any reason I should not fill in the hole to complete my smooth surface? There is a hole in the sheet metal behind the hole, but I can't see that it performs any function or gives access to anything in particular. I do not have the 10 speaker option.
https://cimg0.ibsrv.net/gimg/rennlis...988380d152.jpg |
manual window option.
That hole looks like it’s a remnant from when our cars had manual window winders which iirc was also an option on some later cars.
but surely not in that location....
the manual winder is further forward and up higher |
Originally Posted by mrgreenjeans
(Post 15957871)
the manual winder is further forward and up higher https://cimg8.ibsrv.net/gimg/rennlis...f1a4bb4fe9.png |
Yep, manual window operating location. There are two locations depending on early or late cars.
Those look to be the early version - MAK's photo shows no Speaker hole and they're setup for manual mirrors.. If yours are like these, you should consider selling them - they're hard to come by. |
ok,
I see now the first photo is showing the hole closer to the front of door card than I thought. At first it appeared to me the map pocket was the area on the left side door below the armrest, not the true pic of it being the right hand door card, with the small map holder below that hole, with hinge area to the left. My confusion; totally agree now that the pic appears right in my brain |
Thanks to everyone who replied. It makes sense that the hole would have been for a manual window crank.
