Quick 951 Brake Question
In general, the basic answer to the main question is yes, the calipers off a std 968 will work on an 86 951 w/o having to change anything else.
Sure there are a couple superceded caliper part numbers since 1986 which include the change from 38/36 mm pistons to 40/36 mm in 1987 and then another change from the scraper ring piston seals to the protection cap style (951 351 421(2) 00 thru 03).
And yes, these all show up in the PET program, you just get the superceded part when you try to order the original part number. For example I show the ’86T con-rod as being 944 103 001 00 (is this the forged rod?) but it says its dropped and replaced by 944 103 008 00.
Originally posted by tifosiman
Erich,
If you do this conversion, try to find a set of 4 late offset 16x7 wheels, like D90's or Phonedials. That way you can be certain the wheels clear the calipers and also don't foul the fenders.....
Good luck!
Erich,
Good luck!
Will this all work with the standard struts i have?
Now what about the rear of the car?
Thanks guys for all you input its truly appreciated!
-Erich
-Erich
-Erich
The rear, again, is a simple bolt up. You will need the 4 bolts and 4 spacers from the rear 968/951 calipers in order to bolt them up, along with the proper early offset (86 951) rear rotors (2 of them, for reference). You may need to trim your rear dust shield slightly where it may touch the caliper, depending on which dust sheild is on there (I have seen one that works OK with no trimming, mine I had to shave about 2-3mm worth of material off of it).
Thanks Tifo! I guess we did cover that when we exchaged PM's a few days ago. I have just been learning so much about this i forget what ideas i have already been covered
I appreciate all of the help. Slowly but surely i am figuring this all out! And thanks to you guys im learning a lot in the process!
Thanks again!
-Erich
Thanks again!
-Erich
