Need help removing cruise control computer
I can't seem to figure out how to get to the mounting screws. There are multiple (I don't know how many) screws hold it in place but I can't seem to find a way to access them. I read the info on Clark's Garage but it doesn't go into details.
I could use some advice on this one.
Thanks,
Daniel
Thanks,
Daniel
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
The CC computer should be on the driver side, under the dash, by your left knee (an aluminum box). There are two bolts holding it up -- (maybe 10mm bolts) -- you need to be a bit of a contortionist to reach them. Being small helps here. I get to them by crawling under the steering column on my back.
The near side one is relatively easy to see -- it is at the end of the box -- the narrow end, the edge facing the rear of the vehicle. The second one is located exactly the opposite spot -- the narrow end, the edge facing the front of the vehicle. You'll want an extension to reach them (at least 3in, if not 5in). Install is is the opposite of removal (except more of PIA).
Good luck!
Good luck!
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
