S2 Door Maintenance and Refresh
Hi there all-
I've tried searching but can't come up with a great list of things to do, or a DIY procedure, on door maintenance. I've found a good video on replacing the mechanism and some tips for removing the glass, as well as the Pelican guides. However, I have NOT found a solid list of what I should do if the mechanism is starting to get sticky or slow, or general upkeep on the door latch system.
Can someone here point me in the right direction?
As a second part of the request, because I am seeing some issues with my driver's side door, are there good sources of procedures to replace or fix the lighted lock ****? It looks like mine can just be pulled straight up, and I don't think the little LED is attached anymore...
As always, any help would be greatly appreciated.
Cheers
Glenn
Cheers
Glenn
Hi there all-
Cheers
Glenn
Cheers
Glenn
The door card is also held in place to the door frame by a bent metal bar attached to the backside of the door pull. It feeds through a hole in the door frame. Lift the card upwards to release this bar from the frame.
I think this is the **** you seek: https://www.sonnenporscheoemparts.co...MtMGwtbDQtZ2Fz
Once the card is removed, replacing the lighted **** is a piece of cake. The old one screws off the rod, and the new one screws on, and plugs into the plug...
You guys are great, thank you.
I'm sure I'll keep finding little things that will need repair and this kind of help is invaluable.
Cheers!
Cheers!
when I bought my first Raleigh Record 10 speed in 1973, the bike shop owner, Mr Greenly, showed me how to clean then lube the chain and adjust the derailleurs. he told me that wd-40 is a cleaner but not a lubricant so use 3 in 1 after cleaning. I broke a lot of bones on that thing and so did the guy that stole it while i was working in Yosemite.
I would suggest silicone paste or something non petroleum based that is compatible with the plastic parts.
One of the videos I found strongly recommended the use of a NAPA product, SIL Glyde, a silicone lubricating compound. I assumed it was a silicone grease but the SDS says it's primarily castor oil (!). Any reason not to use MoS2 or white lithium? It seems like they hang out quite a bit longer without caking. The Sil Glyde gets very good reviews, even as a refresher for door and body seals, but I worry about the lifetime of organic based lubricants.
