Late OPRV O ring size
After trying to find the O ring size for late one piece OPRV, (part no. 999 707 144 40) I bought a couple and took some measurements, so here for anyone looking for the info, here are the dimensions,
OD 16mm
ID 12.4mm
Thickness 1.8mm
after checking, there are two O ring sizes, one which is correct, the other should be OK
1.78x12.42mm
and
1.8x12.5mm
OD 16mm
ID 12.4mm
Thickness 1.8mm
1.78x12.42mm
and
1.8x12.5mm
CHD (08-03-2023)
Thanks for posting. Are you changing the inner one too? I understand there's some confusion about taking it apart: one Porsche service bulletin describes a procedure but another official document suggests it not serviceable
OD 16mm
ID 12.4mm
Thickness 1.8mm
1.78x12.42mm
and
1.8x12.5mm
OD 16mm
ID 12.4mm
Thickness 1.8mm
1.78x12.42mm
and
1.8x12.5mm
With my basic understanding of hydraulics, the oil pressure is controlled by the plunger (valve) at the end of the OPRV (not the spring between the two sections), the o rings only seal the OPRV against the crankcase orrifice and the internal one keeps the two sections coupled together with a bit of play so as to allow for alignment variation,
This is my understanding, I could be wrong
Rebuilt and installed the OPRV from my '87 924s today. This is the second time. After experiencing super-high oil pressure (150)and subsequent leakage (!!!) from the valve cover and oil filter, I made my first attempt at resuscitating it with generic O rings. While there was an improvement (90) the oil pressure was still too high. Used the correct sized rings today and noticed that they were a bit thinner. Hope it solves the issue but won't know until the valve cover gasket is replaced which will be done as I redo the TB et al.
Problem solved
