Poor spark cylinder 1 ?
so as part of the restoration of my 1986 924s I had the engine out for a reseal etc and the engine is now back in the car however while trying to set the idle/co2 we have found a misfire/poor spark on cylinder 1.
pull the plug lead on cylinder 1 no effect, other 3 leads noticeable engine change,tested the spark at end of lead less than 2,3,and 4
replaced as part of refurb
Plugs and leads
dizzy cap
fuel filter
we changed the plug to another cylinder and it was ok, resistance check on plug lead and coil also ok
12v on each of the coil terminals with ignition on
continuity check on the green wire from the coil to 9 pin plug ok
resistance check on plug lead bang on
so any suggestions for what else to check much appreciated, may be a red herring however the rev counter has also stopped working I cleaned and checked all electrical plug connections.
I have read a fair few threads on the speed/reference sensors which appear to also be the driver for the rev counter (and green wire from coil ?) so still have to check the gap at these sensors
would the car start if the gap was out ?
the engine ran fine when we took it out the rev counter also worked so pretty sure its electrical/loom/sensor
all vacuum pipes have been checked
any wisdom appreciated on any particular checks required
_________________
Plugs and leads
dizzy cap
fuel filter
_________________
Now had a bit of result but not sure what I fixed so re-checked the multi pin connectors and the wires at the sensors and also removed and cleaned the injector plug put it all back together and happy days running on 4 cylinders nicely so will see over the next few days if this is resolved or temp fix,
rev counter still not working, I did read a thread on pelican who had similar issues and the rev counter came to life once he took it for a run here`s hoping
I bet if you pull back the boots on those connectors, some will reveal corrossion or other wiring issues. Unfortunately, at this point we're experiencing issues that aren't due to the usual book-diagnostic suspects but to age-related rubber, wire, plastic, etc failures
Lindsay seems to have good wiring harness options... or there's some good threads on build-your-own around here
I thought rev counter gets signal from KLR.. not certain though; quick search will find it
