Is Jon Millege still around?
Thanks for pointing that pdf out to me by HEB.
Looking closely, it appears that there are minor differences between the S and S2 cams. Not sure I'm smart enough to interpret what these numbers really mean in laymans terms.
Intake begins opening 1 deg later on the 944S and closes 7 deg earlier.
Exhaust begins opening 3 degrees later but is open for 3 deg more than the S2.
Looks like perfect pair with available stock parts would be the intake cam from the S2 and exhaust cam from the S.
T
T
Yeah, it would appear to be that combination is the best stock configuration for the 2 cam 944s.
Looks like the exh durations are the same with the S2 exh shifted to open and close 3 degrees earlier than the S cam. Int duration is a tad longer with point of opening essentially the same.
Pulled the data on the 968 cams for a look - the Int duration is a big bump from the S and the point of opening before TDC (7 degress before TDC to 52 degrees after BDC). The exh has the same duration as the S and S2, but the point of operation is shifted later than the S (31 degrees before TDC to 1 degree after TDC) which results in an common overlap of about 8 degrees if I'm reading this right.
Thanks and sorry to derail I should prob buy a 951 cam but... 288/280 or 280/272 - they should be the same price, just ask on one of these part numbers and Ill reach out direct 1301804 or 1301805.
