Gas / Petrol Tank Bottom Cover - 944 Turbo
Hi Folks,
Whilst I've been slowly working through the jobs on my 944 Turbo I found that the bottom cover for the gas / petrol tank had totally corroded (possibly due to a slight gas leak from the tank to pump hose).
Attachment 1347604
I've found that the main piece of the cover is still available for a reasonable price from Porsche BUT the inspection hatch / cover that sits over the fuel pump on the wheel side is NLA.
So looks like I have 2 options -
Cheers
Attachment 1347604
- Locate a good condition used hatch / cover
- Fabricate a new hatch / cover
Cheers
After I'd sourced a good used cradle and got it powdercoated (no strap unfortunately) I decided to try my hand at metal fabrication (something I hadn't done since high school).
Strip of aluminimum was ordered and I salvaged a piece from the existing strap, rivetted it together and painted it. Did a test fit before I painted and it is a little tight so hoping I have no fitting issues when I finally get the bits I need to re-plumb my fuel pump (another nightmare).
Attachment 1347014 Attachment 1347015
Attachment 1347016 Attachment 1347017
Thanks!
Thanks!
