944 Cab Roof Help Please (Solved)
Hi All,
Trying to get the top down on the Cab in manual mode to no avail. I have loosened the nuts behind the caps and then unlocked the top from the front frame. The top will only go back about 8" before it stops. It feels jammed. Any ideas?
Cheers
Scott
Edit: Worked it out. Removed the inner panel and found the motor arm installed backwards.....WTF!!!
Cheers
Scott
