Lights help!
The Carnage King
After my accident (see the DEER SUCK! thread) Ive had some lighting related issues. As of right now i cant seem to get any parking lights (front/side/rear) to work on the drivers side of my car. The turn signal works but not the parking lights (or if you flip to headlights the lights dont work then either). I didnt think the fuses were for each side, any suggestions?
You thought wrong. The exterior lights are fused seperately - I seem to recall about almost a dozen fuses assigned. Each side, each filament in the headlights, front and back - Porsche went crazy on lighting fuses. So better check all the fuses out.
Didn't you have a deer strike that crunched the front lighting? What can happen is the little posts that hold the bulb filaments get crunched together creating a short and poof goes the fuse as I think they are all only 7.5 amps.
