Shifting notchy after brake master cylinder replacement
Hello all,
I have a 1986 944 na that has developed a notchy shifting problem. I just changed the brake master cylinder as well as the brake / clutch fluid. Before the change the car was shifting fine. Now it is a bit notchy. Any idea what may have caused this? Do I still have air in my clutch line?
Thanks for your input!
You didn't remove or adjust the clutch MC, correct? If you don't need to adjust the pedal, try bleeding the clutch again; I do it successfully using a Motive bleeder and having my son depress the clutch a couple of time during bleeding. When he doesn't do that, it doesn't work
