Alignment Q'
i had my car corner weighted and aligned at at S-Car-Go about 3-4 month ago and just recently I noticed that it pulls to the left a little ,I haven't hit any curbs that I recall and the tires are aired up equally, the only thing I done since was to replace the bushings in the 968 MO30 sway bar with the Racer's Edge Delrin bushings, will that through the alignment off?
My car pulls A LOT to the left when I let go of the wheel.
Fronts I got 245/40ZR17, and Rears 255/40ZR17
How much do shops charge to do a proper alignment?
You didn't take the spindles off of the struts?
Check to see that the hangers and bushings are equally spaced and vertical. This could throw it off.
I know that a change in camber (tilt in-out) can do this.
Thanks,I will disconect the front sway bar tomorrow and see if it makes a diference
