Strange Cruise Control Problem
The cruise control on my '86 944 works when it feels like working. It works perfectly normal when it does. I try to actuate the lever everytime I am driving on the highway, sometimes the cruise control comes on and most times it doesn't. On a couple of trips on the same day, it has worked on one leg of the trip and not the other.
I have not heard of anyone else having this problem. I am confused.
Any suggestions
Any suggestions
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
If it's an intermittent problem, I'd suspect the cruise control brain. Go to Clark's garage and there's some more info (and elsewhere on the web, like Rennlist search) -- but the basic problem is that the soldering connections get weak over years , but you can resolder the board -- or replace it altogether. The other possibility is the CC servo.
I have the same problem. It works sometimes. Recently I tried using it on a long drive and it took a while, then started working, and then stopped, all in a matter of maybe 6 minutes. It was a serious pain in the butt. I'm going to check out that thing on clarks garage and see if mine is fixable.
