Door Window Channels
Hi Folks - can any of you kind souls help me out and tell me how the window channel is secured inside the door? I had two replacement doors fitted to my turbo prior to the respray and they didn't come with the channels. I managed to source some replacement ones but I'm unsure what screw / bolt should be used to secure them in place? A photo would be great if anyone has a door in semi - dismantled state currently. It is the channel at the rear of the door next to the lock / handle mechanism.
944 531 103 00 Window channel (left)
944 531 104 00 Window channel (right)
Thanks!
Thanks!
IIRC, when I had my door apart last year, there is either a 8 or 10mm bolt and washer at the bottom edge of the channel. There is provision for one at the top as well, but I don't recall that I have that mounted in mine and hasn't created an issue. The channels should have some guides pressed into them. Not apparent in your picture.
