LED Headlights: Hiw Many Watts?
#31
Yes except that wasn’t my point. The e-code lenses focus all of the light towards the front, LEDs focus all the light towards the front, therefore LEDs in e-code housings will reduce side vision which degrades turn-in lighting. That is why all car manufacturers use an adaptive system when they use LEDs, the adaptive system takes inputs from steering and pitch to aim those LEDs to restore the light when the car hits a dip, brakes or steers left and right. I doubt very much they would go to that expense if they thought non-adaptive LEDs alone provided sufficient safety.
#33
I just realized the link I referenced but did not provide might not be as easy to find as I thought, as the initial point of the thread was about designing a sealing mechanism for the LED bulbs. Also note that this directly pertains to the European 8" H4 housings in the 928, although it should apply to the 7" H4 replacements for sealed beam lights as well I would think.
https://rennlist.com/forums/928-foru...l#post14323832
#34
