Driving misconceptions
#31
I'm aiming for 400# to 500# spring rates all around the car. I have the 968m030 sways and they help quite a bit assuming they are mounted correctly and the bushings are perfect. Add slicks to the equation and now I have to worry about strut tower flex!!!
What I want to discover is how much of a difference there will be between AutoX and DE setups.
#33
Well to return to a suggestion in the original post, here's my suggestions for a good setup:
1. Minimise body roll, squat, and dive with stiffer springs and anti-sway bars. Set camber accordingly to maximise contact patch area during cornering.
2. Maximise grip with the softest springs you can get away with, without compromising point 1.
3. Use spring rate ratios from front to rear to alter the balance of the car by affecting weight transfer.
4. Use damping rates to alter the RATE of weight transfer from both front/rear as well as side to side. Use high and low speed damping to isolate damping effects for body roll and bumpy surfaces.
5. Use the brakes for stopping and the accelerator for both accelerating and matching the engine revs to the rotational speed of the driveshaft while the car is moving. The goal is smoothness of power delivery, both in acceleration and deceleration.
6. Always maximise the grip of your tyres to the limits of the car's ability. The sum of the forces laterally and longitudinally must approach 1, where 1 is the limit of traction. Strive to be as close to this limit as your vehicle's power will allow. This means that, yes, you MUST learn to turn and brake at the same time. It's essential to being fast, despite being counter-intuitive.
7. And here's a tip from Michael Schumacher. Don't just drive fast at some places. Always ask yourself how you can be faster at the point on the track you are right now, no matter where that is. Then work it until you are faster. Use data logging to be sure.
Sorry for the track bias. But this applies equally to road driving too, except the bit about going as fast as you can all the time. Only go as fast as you can when you see red and blue lights behind you ;-)
Clayton
Clayton
#34
#36
Thanks Brendan. It's just a standard 968CS, though. Except for the rims in the pic. They're rip offs of the standard rim that I use for the track. The originals are white.
Your car looks nice too. You should definitely take it to a track day and get some driver training from experienced owners and then get out there any enjoy it. All Porsches should be taken on the track regularly!
Clayton
Clayton
#37
Originally posted by BeerBurner
I've always noticed that at the autocrosses, the cars that look like they are going the fastest are actually the slowest, and the cars that look like they are the slowest are actually the fastest.
Kevin: (Not the braking thing again!) Just a quick comment: throwing a boat anchor out the window is also an effective way to slow a car down! But it isn't an effecient method! Much the same way, using the engine to slow a car down 'works,' but not too well. Just because everyone is doing it, that doesn't mean it's the best way to do something! (Which is why this thread was started! )
Great input and comments guys! Keep them coming!!
-Z-man.
#38
First off, Engine Braking should not be use to slow down a car on a race track (Unless your brakes are Malfunctioning) You should downshift continuosly while on the brakes to match gears with engine rev. 120 in 4th hard on Brakes, Downshift to 3rd (Still hard on brakes) Downshift to 2nd (Still hard on brakes) Release brakes Make turn in Maintain throttle level Reach Apex Slowly apply Gas Reach Exit Feather on Full throttle. Repeat for next turn.
Second. If you ask anybody that drives a large truck (Aka a Semi with full load) in the mountains and they will certainly tell you that you use the engine to slow down. Ever heard of a Jake Brake? If they used their brakes to slow down the entire time, they would have not brakes left halfway down the hill. Same applies for them on the highway. Also, I am sure that you guys that trailer your car fully understand how it can be very necessary to engine brake while towing.
#39
Originally posted by Z-man
A side note to that is: sometimes you have to drive slow to go fast.
The same thing applies when you're out there by yourself. The fastest you've ever been at a particular spot is great in itself, but it isn't a lot of use to a good lap time if it messes up your progress in the next spot.
I'm sure you must keep this in mind when thinking about Schumacher's comment. He means always think about how to be fastest wherever you are, but if that means reducing speed to ensure you are even faster later on then so be it. A fast exit to one corner may not make for the fastest entry to the following one.
Always try to think as many parts of the track as you can ahead, and try to keep things flowing so the overall pace is fastest. It's the total lap time that goes in the record books, after all.
Clayton
#40
I don't get lapped by too many trucks on the circuit, though.
Clayton
#41
TRB0 GUY
Mario Andretti, among many other purists like to engine brake to stabilize the rear... just a thought...
Clayton, I didn't understand his comment as well.... but anyways, explain to me how where the jacking force in corning comes from. If it isn't a part of the cornoring force, as Carroll Smith seems to show (correct me if I'm wrong) in his books, where DOES it come from??
iloveporsches... yyuuuupp, it sure is how ya drive an FSAE car, though we have the benefit of a sequential
-Kevin
-Kevin
#43
I have no idea how engine braking can stabilize the rear. :?:
-Z.
#45
Clayton
