Driving misconceptions
TRB0 GUY
Originally posted by gnosis
Snap oversteer is caused by weight transfer. It can be adjusted by suspension stiffness across the car, but stiffness per se does not cause oversteer.
Originally posted by gnosis Relative stiffness has an effect, though. Likewise, body roll does not cause weight transfer. In fact body roll does not affect weight transfer in the slightest.
Learn to brake with your left foot.
However engine-braking can sometimes be vital on the freeway, especially when you are going 150mph and a F*&#ing truck cuts into your lane abruptly.
Edited.
Edited.
TRB0 GUY
Well I got cut off at over 115 on a downhill bridge... I actually liked my threshold braking, personally, lol... I managed to match speeds with the guy about 10-15ft from his bumper (long story!). Why would you bother left footing it, however... or are we getting into left foot braking and clutchless downshifting now?? ... I think I might need a goodnight's sleep to dive into that one (uh oh), lol.
gnight guys,
Kevin
gnight guys,
Kevin
Kevin,
I agree that body roll has annoying effects for contact patch, and thus it should be eliminated. It also has a destabilising effect on the driver because humans can handle lateral accelerations much better than rolling accelerations. This is why people get more car sick in cars with soft suspensions, the same as they lose their lunches on boats due to the rolling motions of the waves. Note that nobody loses their lunch in elevators because they don't roll. Agressive negative camber can compensate for body roll, but it affects accelerating and especially braking efficiency by reducing the contact patch when you're not rolling (and you're not rolling when you do most of your braking and a good deal of your accelerating). So you're better off having less body roll and requiring less negative camber.
But weight transfer remains the same no matter what you do with body roll. You can't "absorb" weight. It has to be distributed between the four wheels (or three if your setup can't keep all the wheels on the ground - a no-no in itself).
Regarding Andrew's comment about left foot braking, I fully endorse it. I find it to be a fantastic technique. I use it all the time on the road and track, and with the Super Tourer it was easy because you didn't have to use the clutch. You could drive the whole race like a kart if you liked.
However I don't understand Andrew's comment about engine braking to avoid accidents. Stopping quickly is definitely the job of the middle pedal.
Clayton
Clayton
gnight guys,
Kevin
gnight guys,
Kevin
If you want to go slower, just blindly keep making your car stiffer. You'll wonder why it feels so "solid" but your lap times suck.
Clayton
Clayton
Either way you look at it, body rolls sucks.
Body roll changes camber, making the car's handling less predictable, and since the camber is changing so much and leaving it's optimum range, the available traction from the tires suffers even more.
And ABS stops with a few thousand horsepower of retarding force. Engine braking is almost as useless as coasting. I can't see how relying on engine braking can slow anyone down fast enough to avoid an accident. If I relied on engine braking to slow my car down from 100km/h, I'd still be rolling along at idle 20 minutes later.
Sorry, but I just don't understand why people won't use the brakes. That's what they're for.
Clayton
Clayton
I have to agree with the engine braking being useless. My dad used to do it in my car and I told him a valve and bearing job is more expensive than brake pads. USE THE BRAKES.
He doesn't drive my car much anymore..
Rich, I agree that around 200lbs isn't enough for a high performance road tyre on a relatively smooth surface like a race track. My guess is around 400 - 500lbs for front engines Porsches, but I haven't tried anything above the standard 160lb springs in my car. I will get around to it when I rebuild my suspension. But I also have the issue of whether I want a track car that I use on the road, or a road car that I use on the track. Unfortunately, these setups are different. And it's not just down to springs at each wheel. The anti-sway bars are effectively springs too.
But I agree totally with your comment about body roll being bad. I hear that absolutely none isn't a good idea because humans detect movement and respond better when there is some roll, but I'm talking tiny amounts.
The trick is to reduce body roll without increasing your spring rates so you don't cause traction to suffer. Tricky, and to date there haven't been any good solutions to this problem.
Clayton
Clayton
full brakes (not locked) + engine braking = locked rears and a spin. Don't do it. Your brakes have ample capacity to lock your wheels. Your engine isn't needed to help out with that.
I should point out that this is hardly an issue since the engine braking adds so little to the braking force. Even without rev matching, you'll spin the engine up much easier than you'll lock a wheel. But if you're rev matching properly with good heel-toe technique, you can slip the gear in without unsettling the car even the slightest, and this allows you to brake right on your limit and be confidently ready in the gear you need for corner exit.
Clayton.
Clayton.
