What is the difference between a 10k 944 and 20k 944?
Yeaaaa. I've been wanting a sports car for a long time. I'm about to finish my MBA so this is my gift to me. I could just as easily go with a new mustang or something and probably be faster and more reliable but I'd like something vintage, lighter weight, and a little more easy to work on myself. New stuff has become quite complicated to work on alone.
If you're talking 944 turbo values, yes they can vary for all the reasons already mentioned, condition, maintenance, options, mileage, etc. Also, don't forget that the early turbos (86 to 88) were always priced considerably lower than the later (88S to 91) cars. If you took an 87 turbo and an 89 turbo of identical mileage, condition and records, the 89 turbo is likely worth twice as much as the 87. Even for a parts car, the later 944 turbos have a lot more rare and desirable parts than the earlier models.
What is the difference between the 86-88 and later models turbos? I'm sure there is a thread somewhere describing this. Like you said though, more desirable and more rare features also says more expensive to maintain to me and that is not what I'm after in this. I understand there will be costs but i'm looking to have fun. Not at the over all value increase.
I frequently miss my 944. There were lots of good things about it, and I hope that the new owners have had a good experience with it, as well. If you haven't owned a 944 before, I might suggest an NA before a Turbo, to learn what you can and see if it is for you. My situation turned out to be ,"I love the handling, build quality, ergonomics, aesthetics. I just want it to be modern with respect to maintenance, reliability and power." The answer was Cayman or BRZ. Cayman won, by a long margin.
My advice is to ensure that body/paint are all in excellent shape, no rust anywhere. If there are mechanical issues and you are willing to put time into that, you can fix those. Most people (myself included) don't have the skills, equipment, or space to properly do body repairs. Those end up being extremely expensive. If you want to spend lots of time fixing because you enjoy that, get a less expensive car up front. If you want it to drive on a regular basis, buy one that is already sorted and more expensive up front.
