Torsion Bar Size
924S, 944, 944S with standard or M474 suspension: 23.5 mm
924S, 944, 944S with M030 or M637 suspension to end of '86: 24.5 mm
944S2 with standard or M474 suspension: 24 mm
951 with standard or M474 suspension to end of '88: 23.5 mm
951S, 951 '89 and later: 25.5 mm
924S, 944, 944S, 944S2, 951 with M030 or M031 suspension from '87: 25.5 mm
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Don, do you mind if I copy that to the tech-session site under the effective rate article? I assume you compiled the numbers from the factory manuals? Will keep me from having to look it up every time ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
article seen here: http://www.tech-session.com/kb/index...x_v2&id=22&c=4
