View Poll Results: Where do your front cage bars go
My bars go through the dash
9
64.29%
My bars go in front of the dash
5
35.71%
Voters: 14. You may not vote on this poll
Show me the front of your rollcage
Old 09-12-2018, 09:24 PM
951and944S
951and944S's Avatar
A coat of shampoo rubbed on then lightly off keeps windshield from fogging.
You can buy a 12v (with cig lighter plug) heater/defroster from O’Reilly that you could mount to top of dash.
T
Old 09-13-2018, 08:23 PM
Noahs944
Noahs944's Avatar
Interesting T!
I wonder what Porsche did to counter the fogging problem in the 80s and 90s... anyone know?
Old 09-13-2018, 09:53 PM
MAGK944
MAGK944's Avatar
On the subject of fogging, does anyone have a heated windscreen instead of a blower?
Rick Evans 944 Heated Windscreen
Old 09-21-2018, 05:10 PM
PDX-944
PDX-944's Avatar
while we are here... im having a cage from 944cage.com put in (hanksville hotrod)
but, due to classing, I have to keep my interior intact other than minor dash cutting.
I was hoping to find pics here of cages working around the dash, or with minor adjustment.
Post number 2 Is pretty useful, I may end up doing something like that
Old 09-22-2018, 11:53 AM
Noahs944
Noahs944's Avatar
PDX 944, Hanksville makes nice product & I find their website is perhaps the best source of photos for going around the dash.
The problem I have with it is FIA states something like "only one bend" on the a pillar and I noticed Hanksville has "s bends" around the dash. Is it really a problem? I don't know. Thoughts?
Reference the top car (so beautiful) "Karen's":
http://www.hanksvillehotrods.com/Pro...6/Default.aspx
Old 09-22-2018, 11:56 AM
PDX-944
PDX-944's Avatar
I'm not sure where you are looking... Their site has no pictures of vehicles with the dash in place, and there is no S around the dash...?
Old 09-22-2018, 12:00 PM
PDX-944
PDX-944's Avatar
Old 09-22-2018, 12:05 PM
PDX-944
PDX-944's Avatar
Interesting, on another page I do see some with s bends I'm guessing those are custom ordered, as their kit doesn't have the S.
Edit : reading that page, it indicated those were custom orders by people not wanting to cut the dash.
Old 10-15-2018, 12:41 AM
Van
Van's Avatar
I now use defroster elements on the windshield (like the rear window). You can get self-install kits and they work really well.
Old 11-20-2018, 08:07 PM
Kurt R
Hates Family Guy
Kurt R's Avatar
GPA951s and others who ran your front bars through the dash - how did you get the bars between the a-pillar and the pocket for the hood hinge? Did you move the hinge and the pocket inboard?
I was at the cage builder's today and rejected their first attempt. They made a halo bar at the roof and then were going to run the forward bars up to it. The thing I didn't like is that puts the front bar below the header above the windshield, and the bars at the top of the doors are about an inch lower than they could be. So I want him to make one bar from the rear hoop to the front of the door, and then add the bar at the top of the windshield. That puts the side bars higher, and puts the front bar further forward and away from your head. I broke my visor on the front bar in the 944spec car, it's a bolt in cage and I hate it.
Old 11-20-2018, 10:02 PM
Otto Mechanic
Otto Mechanic's Avatar
Hey Kurt -
This caught my attention since I've been thinking about maybe hiring someone to reproduce a bolt in Matter cage for my Firehawk tribute. Aside from bashing your visor on the bolt in cage, was there anything else? Was it a Matter?
Regards,
Old 11-20-2018, 10:48 PM
Kurt R
Hates Family Guy
Kurt R's Avatar
No, I think it's an Autopower cage. There's a piece of padding where the label is. It's made to fit a car with the interior intact. The front bar is below the front header, about an inch below.
I like the looks of the Matter cage, I think it's a good choice. I'd consider welding it in rather than bolting it, and depending on who you're going to run with you might have to add a second door bar.
Old 11-21-2018, 03:03 AM
Otto Mechanic
Thanks, I've never seen a Matter cage so I'm interested in hearing about any possible problems. I know no one has problems building welded cages for these cars but that doesn't help me deciding if it might be a bad idea to have a replica Matter cage built, so I'm always searching for experiences with that design.
Regards,
Old 11-21-2018, 07:53 AM
MAGK944
MAGK944's Avatar
Regards,
You should contact Wiechers if you need an aluminum bolt in cage like the Matter. It won’t be exactly the same though as it will be built to today’s regulations rather than last centuries.
Old 11-21-2018, 10:55 AM
wildcat077
wildcat077's Avatar
If i can give you some advice regarding caging your car , i would suggest you have your seat installed and sit in it with your helmet on and assume driving position before taking measurements ...
Once everything is welded in place it's too late !
You want adequate head room as well as room for your knees , whereas it's better to have the transverse bar mounted above the steering column. The previous owner was a lot shorter than me and i had to mount the seat brackets
to the floor as i had minimal helmet clearance with the sliders.I also found that the top windshield bar was a few inches too low, you want enough space where you can easily jump out of your car through the window opening in case of an emergency.
I also ended up making a new dash as the original installation was a real abortion ...
A lot of things to consider !
Quick Reply: Show me the front of your rollcage
