Shipping an Engine
Shipping an Engine
So...did a search on here with no success.
Asked Google and found this video -
Basically looking for someone with the T-shirt to share your experience. Need to pick up a short block this weekend and will be using my little trailer to place the engine on and strap it down for bringing back to my Toy Box.
TIA-
TIA-
Last time I picked up a 944 short block my friend and I just lifted it into the back of my SUV and used a ratchet strap or 2 on the interior tie downs. If it was a full engine then well would have been a bit more complicated.
For what it's worth I have shipped engines and transmissions via Fastenal 3rd Party Shipping and you would be hard pressed to beat their prices. Your situation sounds a little different in that you are picking this engine up and moving it yourself. That's awesome that you have access to a trailer, that should make things easier.
When we shipped the engine below, we lifted it by the points on the engine and put in the back of a Toyota Sequoia. At Fastenal, they pulled it out via their forklift. That's another nice thing about the pallet is that you can for under it with a fork lift or a pallet jack if you have access to those, plus it keeps the engine up off the ground, minimizing the potential for damage. The pallet also gives you something to strap to. Not sure if it is clear in the pic, but I ran a couple of ratchet straps around the top layer of the pallet and over the top of the engine. Another thing to note is that the engine will have a tendency to tip over. That is why you see the small cribbing I built under the headers in the pic.
Of course there are plenty of ways to do this, but my suggestion is find a pallet (they are everywhere and practically free), get yourself some ratchet straps, and come up with a way to support the exhaust side of the engine (harbor freight moving blanket? lots of ways to do this),
I'm not sure if your trailer has a ramp, but if it does, you might be able to wheel the engine up onto your trailer using furniture dollies like the ones shown in the pic. Otherwise you're likely going to need an engine lift and chains to pick it up and place it on your trailer and of course to take it off when you get home.
