rear wheel bearings
i replaced my rear control arm and i'm putting it back together.......but i dont remember where 2 of the spacers go does anyone have a picture or link that will help?
What year is your car?
If you've got the Aluminum rear arms, you'll probably find the right picture here: http://home.nycap.rr.com/projecthuli...ures%20Day%203
-Jon
-Jon
Would you by chance be looking for something like this? This is early ('83 to '85.5) stub shaft/bearings/spacer stackup. The late model cars didn't use spacers inside.HTH
![](http://forums.rennlist.com/upload/00000012.jpg)
I'm keeping that picture anyway! Sure wish I had it in a recent go around about what went where. Was a big disconnect as to what an inside and outside chamfer was.
When you look at all of the spacers you see that the 350 ft lbs just pinches all against the inner race of the ball bearing -- lateral force. The outer roller bearing is for the vertical forces.
Getting ready to do a front hub. Sure wish I had a digital camera to take a picture of the bare assembly.
