Timing belt change questions
I am preparing to gather parts to do a water pump/timing change on my '87 NA and I have a few questions...
I read where it says you need an updated rear timing cover with the new style water pumps. how can I tell if I already have this ? I don't want to be caught without everything I need once its apart.
Which is the best water pump to go with ? I see so many choices out there.
Thanks so much
Thanks so much
You don’t need to buy a newer style rear timing cover because you can modify yours to fit if needed. On the water pump the consensus is a rebuilt one from Zims.
