brembo caliper components?
Hi, can anyone tell me if all the caliper components are availble?
I need to rebuild a 4 piston caliper, but the metal retainer, the one that is bolted in the caliper that guides the pads is mangled and needs to be replaced.
Yes, as repair kits, p/n 96435195901, 96435195900, 99935295900, or 99935295901 depending on front vs rear, upper vs lower, 951S versus 951/944S2. Download the parts diagram from porsche.com, it's in there.
for the plate you can order OEM from Porsche (Sonnen works well for me from a cost standpoint for new parts).
You might try one of the dismantlers (Lart can probably hook you up if you reach out directly via PM here or via his eBay store).j
Darn, well--- giant fiasco with Cardone. siad they could rebuild it for $60(through NAPA).... sure lets give it a try....Now its completely useless! anyone have a spare drivers front brembo? or a junk one i can get the retainer off of?
