944 s2 spacer question
I have a 1991 944 s2 with oem 17 inch cup 1 wheel( 968 ) with stock suspension.
Does somebody added spacer with this set up? Which ones?
You shouldn't need a spacer to run cup 1's on an S2 as they clear the hub and would be the proper offset. If you're looking to push the wheels out to make them flush, there are spacers out there. I run a thin, 5mm spacer up front on my S2 to clear the bearing cap with a set of 996 17" wheels, i DID have to put in longer studs and switch to steel lug nuts to make it "safe" for high speed cornering though.
Yes i forgot to tell i want to push them out and want to know what is the max spacer i can use.
