Tarett Front Sway bar broken mount
"both a horizontal and vertical force on the bracket with force resultant trying to push the vertical support bracket forward. This puts the bracket in a shear mode."
That sure looks like what happened here. I am going to be very careful in setting this up once I get the new mounts as a shear-failure at speed could be a disaster. If both of the mounts gave up simultaneously then there is nothing to keep the bar from dropping. Not sure if the arms would bump off the tie rods, but I'd hate to see what would happen if the leading edge of the bar were to hit the pavement at speed.
So the good folks at Tarett send a new set of mounting brackets, which I just installed. I disconnected the drop links to ensure that there was zero binding as I tightened up the brackets and the bearing blocks to the new brackets and then reconnected the drop links once I ensured no binding.
Anything else I should be on the lookout for? Since I don't know definitively what caused the initial problem I am going to be very wary and keep an eye on this, especially before/during/after track days.
Reset set the spline arm on the other side to match using the above procedure
