Reset Airbag Light!!! Yes!
Old 12-23-2003 | 07:17 PM
Josh B's Avatar
Josh B
Default Reset Airbag Light!!! Yes!
Took three tries but that means too less warning lights on the dash - now to get rid of that pesky brake pad light
Old 12-23-2003 | 07:32 PM
jabbadeznuts's Avatar
jabbadeznuts
HEY!!! Alright Josh. when we did the brakes, the sensors were not worn IIRC. Could it be the backs?
Old 12-23-2003 | 07:55 PM
aribop's Avatar
aribop
Josh, help me out.
What sort of black majic did you use to get that sucker to work??
Old 12-23-2003 | 10:14 PM
Josh B's Avatar
Josh B
Hey Alex - pulled off the driver's side wheel and found that I had not plugged that connector all the way in. That fixed it. Now I need to work on getting that parking brake switch to work right as that is the bottom layer with the exclamation light
Albert - not sure - I just tried three times and was grounded to the battery. Also I used the 20 sec procedure - not sure if we were doing 20 or 15 - Ign on and grounded 5 sec/off 5 sec/grounded 5 sec/off 5 sec/ign off. Also I used the dash clock timer - maybe that is the voodoo
Old 12-23-2003 | 10:21 PM
Campeck's Avatar
Campeck
Campeck Rulez
aahahhahaha
Josh must know more about cars than you dad
lol
so you gonna let me drive on the highways now?
Quick Reply: Reset Airbag Light!!! Yes!
