cable/wire disconnected on back of engine
Having not found out why my engine still fails to start i went over all the vaccum lines and wiring in the engine and found a wire at the back of the engine disconnected. The problem is i don't know where it goes/plugs into. The wire has a 3 prong plug on it, and has a rubber boot around the prongs.
This wire is from your temp sensor to your DME i believe. I had the same problem recently. The wire should be mounted in the bracket with the square whole attached to the block. My connector finally corroded away and was grounding on the bracket. Car seemed like there was a reduced power or no spark issue. When it failed to start I thought it was the DME relay. Purchased one from Pelican but while I was waiting for it to come in I went back over the engine and found the short. Long story short, I repaired the connector temporarily. I am still looking for the original connector. If any one knows the part number let me know.
Originally posted by Wagz
Where does it hook up?
![](http://forums.rennlist.com/upload/sensors.jpg)
My problem was actually number 17 in your diagram. What page of the manual is that digram. It appears that it will have the part number I need.
Wagz, Is this the smae wire your talking about?
![](http://forums.rennlist.com/upload/sensors2.jpg)
Rob, Thanks got the part number now I'll research the price and supliers. Thanks for the PET ref. I conducted a temporary fix using PVC tape to isolate and wrap the connection. The sensor connector that ran through the top of the bracket was so brittle it fell appart in my hands. The wires must have been arcing and then when they hit the bracket they shorted out. It really tee'd me off. At least I have a spare DME relay in the glove now.
Wagz, is this the wires you were talking about?
where does number 24 connect to cuz i think thats the connector thats out, looks like the same housing and the other end looks like what it is connected to. it is a 3 pin connector. would that cause my engine not to turn over because it is the tdc sensor.
