Think you can fit this amp in your iddy biddy 944????
Old 12-19-2003, 02:35 AM
944S2NUT
944S2NUT's Avatar
Default Think you can fit this amp in your iddy biddy 944????
http://cgi.ebay.com/ws/eBayISAPI.dll...category=18797
Old 12-19-2003, 02:52 AM
theedge
theedge's Avatar
Seems to be pretty light if a skinny little kid like that can hold it so easily...
Old 12-19-2003, 02:56 AM
led
led's Avatar
It would fit just fine... on roof racks!
EDIT: the way that guy's holding it seems too light. But seriously what in the hell do you need 24KW for, an earthquake generator?
Old 12-19-2003, 04:22 AM
dualblade
dualblade's Avatar
or a better question, what generates the power to power the amp? a few extra batteries in parallel?
Old 12-19-2003, 05:38 AM
944S2NUT
944S2NUT's Avatar
ACtually it needs some other amp to go with it.
Old 12-19-2003, 07:11 AM
brrt50cal
brrt50cal's Avatar
What subwoofers could handle that kind of power?
Old 12-19-2003, 08:44 AM
Wahoogie
Wahoogie's Avatar
Well I guess if you filled the back of your escalade with 15's you could manage something.
Old 12-19-2003, 08:54 AM
MPD47
The Carnage King
MPD47's Avatar
*You will receive a State title if you compete with this D4
LOL!!!!!! Hmmm wonder if you get cash back if you dont win?
Old 12-19-2003, 09:35 AM
Dave
Dave's Avatar
This Auction is for a **CUSTOM MODDED** Earthquake Powerhouse PH-D4 24000 (24,000) RMS/Continuous Power amp. The amp has gone through manny changes to get *modded, The power supply has been upgraded, resistores, caps etc....The amp is stable at .25 OHM and below **10 YEAR warr on this MONSTER
It would weigh more than the car, and a 944 doesn't have the towing capacity for the generator you'd need to power it. I wonder how much heat that thing would produce (if it were real). A little math fun, 24,000w rms=almost 34,000w peak (note seller's use of the word "continuous"). Anyone know the output voltage of something like that?
All amps make heat, an efficient amp makes less heat but they all make some. Heat, when produced electrically, can be measured in watts. Amps consume power in order to work, the amount they consume is dictated by how much power they put out and how much heat they make doing it plus any power used by fans, lights, switching relays etc. If we had the output voltage and efficiency of the anp, we could see what it would take to power it. I have a feeling that I've built TV stations that consume less power.
Old 12-19-2003, 10:06 AM
Antonio951
Antonio951's Avatar
i wounder if it would blow the windows out of the car if you get a some real big subs. I have a itty bitty mtx amp and 2 10's (mtx) in my 944. Sounds really good but man that think would blow the windows out.
Old 12-19-2003, 11:37 AM
Bryan
Bryan's Avatar
24,000 watts = 24 kW = 32.18 hp
Whoa.
My 944 has the stock stereo and my home system is at most 35 watts per channel and is all vacuum tubes.
What's my problem? Heh heh heh.
Bryan
Old 12-19-2003, 04:01 PM
944S2NUT
944S2NUT's Avatar
http://www.earthquakesound.com/dbdrag_2002.htm
Earthquake PHD2 (x26) 174.2 dB OMFG! is that possible in a car/truck!
Here is the DB rating system.
Old 12-19-2003, 04:16 PM
I-Wana-951
I-Wana-951's Avatar
6 grand is kind of expensive for loosing your hearing....
Old 12-19-2003, 04:18 PM
Dan Gallagher
Dan Gallagher's Avatar
woa, where have you been
Old 12-19-2003, 04:47 PM
Campeck
Campeck Rulez
Campeck's Avatar
AMP!?!!?!?
ohhhhh haha
I thought it was some kind of guitar!!!!
Quick Reply: Think you can fit this amp in your iddy biddy 944????
