Rubber Grommets
Rubber Grommets
Does anyone know of a source for these rubber grommets or a replacement option?
I know that they come from the factory already on the wire, but is there a replacement option?
View showing the plastic bracket the rubber fits into
You can get them from 928srus. At $28 EACH ($500 for all of them), it's a bit steep but it's your only source. Alternatively you can use a piece of hose slit in half and then put a piece of heat shrink tubing (with glue inside) over top to hold it in place. It's how the PO of my car redid them.
https://rennlist.com/forums/928-foru...es-mounts.html
