Rear hatch mount problems
Hi guys, New here and to the 944 world with an 83 that I picked up a few weeks ago. Runs and drives great so far, full service records back to 1992, a bunch of extra parts, and I've fixed a few things here and there. EXCEPT for this darn rear hatch, which actually then makes the car un-drivable because it pops open when I hit a bump. The rear locking pins were completely rusted and spinning freely in the pin mounts because the pin mounts were corroded. So my first plan was to try and get the pins out and replace them and the mount. But in order to do so I have to get the bolts on either side out to put the new mounts in. Those are also rusted completely and the PO stripped the heads. So now I am at the point of trying to extract them, until one extractor broke off in the screw. So now I am trying to drill them out, very slow and painfully.
My question is: Do I continue to try and drill these bolts out while these upper mounts are on the rear hatch or do I take the upper mounts (dremel the glue off?) off the rear hatch and drill out or replace with new? I can't find out how they are attached to the rear hatch, a bunch of epoxy it seems? And those upper mounts are ~$100 each so I was hoping to salvage and chase the threads to re-use them. But, I don't want to keep tearing this section apart until I can know how I am going to put it back together. Any help appreciated.
Completely rusted pin in mounts, my starting point.
During extractions, the heads came off so at least I was able to remove the cover, get the pin and pin mount out...but then the actual bolts
Bolts, in the holes, waiting to be drilled out or have this whole thing ripped off the hatch and start over.
The other side waiting patiently until I have a working plan
