Brad Penn Oil
Brad Penn Oil
I have been using them for a while because of ZDDP. Looks like they have been rebranded to Penngrade, their website never mention ZDDP addictive. That said SummitRacing mentioned it has ZDDP... Is it still a safe oil to use?
I just got a shipment the other week. It scared me when I saw the new label. But on the bottle it says it has the ZDDP. It's still the same green oil. Enjoy!
Administrator - "Tyson"
All oil has ZDDP - yes, every single bottle of motor oil has ZDDP.
The issue is how much.
Way back most oils had over 1500ppm.
For most of the life of the 944 1100/1200ppm was the norm. Sometime around 2001-2002, new government mandates wanted to save catalytic converters so most new oils from there on out had 800/600ppm. This is where the trouble started.
Every synthetic 15/20w-50 and most non-synthetic I've found as the 1100/1200ppm ZDDP levels since these viscosities are not made for modern cars, they are not held to such standards.
The only area where ZDDP is needed is between the cam & lifter since 944's have flat tappet cams. This is really a much bigger issue in classic cars with very tight valve springs and radical cam grinds, but better safe than sorry.
