Project 944 - The wiring mess
I bought a project 944 on the weekend, the catch. The wiring is destroyed in some places. As far as I know the DME loom for the engine works fine.
So there are a few issues off the top of my head
I've listed a few things under the images that I'm unsure about.
Does anyone know of a wiring diagram that is half decent?
Here is the video of the dash lights, indicator and revving, its very odd.
https://photos.app.goo.gl/IzH0vHreFWxEutQx1
Centre console switches
The mess of the centre console, gauges, air con pot? maybe?, unsure why there is that relay there, headunit wiring and breakout box.
Centre console gauges, warning lights, and headlight switch.
Fuse box
Random wiring coming of the fuse box
Unsure what this plug is for? There was also a relay up there (for ignition maybe)
Dash with no gauges, you can also see that relay I was talking about
Glove box insert removed.
- Wiper switch doesn't work
- Headlights do not work
- Indicator dash lights always flash, when the car revs it changes which lights are flashing, see video.
Fuse box
If you Google search you can come up with wiring diagrams. It appears that the connector pictured has been replace looking at all the splices. Poor grounds can cause all sorts of funny things to happen. Search this forum, Pelican Parts site and 944online to find out about cleaning your grounds.
