Speedo Sensor
Speedo Sensor
Can someone please explain to me how to remove the transmission speedo sensor that sends "impulses" to the speedometer and if there is a way to check it before ordering a new one to replace it?
Thanks in advance.
Thanks in advance.
Its a threaded plastic sender that you can remove by unplugging it and turning it off (mine by hand). Mine was physically smashed by a CV joint letting loose so no testing possible, I can't help you there.
