hit BUMP, engine died, car is stranded
1. Speed reference sensors. Had similar problem. Follow procedure in Clarks garage to adjust them. Check the connections on them before doing the procedure, very easy to come disconnected/loose.
2. Coil. If was going bad, a good bump like that could have killed it.
3. Get the roadside assistance with your cell phone company, most have a towing allowance and is cheaper than AAA.
Good luck....
Good luck....
