Waterpump possibly "Wurring"?
I've noticed my engine is making a wurring sound, and I can't place
where from. From experience I'm thinking it sounds like a waterpump
that's slowly failing, but mine was done just this last spring.
Any suggestions as to what I might check out?
Anything I should look for?
What kind of water pump was used? Was it a new unit, or rebuilt? Depending on the quality of the rebuilt units, they have been known to fail abnormally early. I paid extra for a new pump to avoid this. The only worthwhile rebuilt units are the ones the dealer sells.
Another possibility is that you have a worn roller or sprocket. Are you sure the noise is coming from the pump itself? Try taking a long screwdriver and placing the tip on each of the sprocket/roller bumps in the belt cover, and putting your ear to the handle like a stethoscope. Your sound may be coming from somewhere else.
Yeah, I'll try that trick. I should have thought of that myself.
I'm not sure about the waterpump. The PO replaced it, but couldn't find
the recept for it, and he didn't know if it was a rebuilt or new. I'm not
sure I can afford this right now, so I'm trying to diag it as best as I can
before doing anything.
To check belt tension properly you need a very expensive special Porsche tool. Your best bet is take it to a quality Porsche specialist shop (not neccesarily the dealer) and get them to check it. BTW, any shop that claims to be a Porsche specialist and does not have this tool should have you running away. Seriously.
