Quick hatch glass question
Set to Full-Auto
Hey guys, does anyone know if the 924 and 944 glass pieces are the same. I know the frames are different, but is the glass the same? TIA!
Sharky,
I am not sure but I felt bad you hadn't gotten a reply yet. Hate when that happens. I do know you can see through both though. Hope you get the info you need.
From the Parts and Tech reference catalog-
rear lid
924 1977-82 Part# 477 827 027 G
924,944T 1980-85 Part# 944 512 929 04
All 1986-88 Part# 944 512 929 05
There is a tech bulletin #9
The diameter of the wiper motor hole has been changed from 16mm to 26mm. Changed as of:
VIN 94_NK45 2466 944/944S2
VIN 95_KN 15 1328 944 Turbo
Also Modified were the mounting plate, wiper motor, hardware, wiper arm and wiper blade.
Greg
rear lid
Greg
I think, and dont quote me on this, that the 924 glass is not as thick as the 944. Someone was telling me a while back about switching them out to save a little weight. Don't know how true it is though....
They are not; the 931/944 winged hatch glass has allowance for the bolts for the wing. The 924 (no wing) hatch does not. I suppose it's possible that the 944 has thicker glass for better noise insulation. Of course, lexan's always lighter...
(just put one together for the racecar)
