944 S2 cold weld cam fix???
Hi there,
Got a question for you. I had a cam tensioner fail, and it ate up my exhaust cam. I found a place called Part Works that re-sprockets the old cam with a cold weld procedure. After putting it all back together, it runs great, but there is a light ticking sound that almost sounds like it is coming from the fuel injector on the number 2 cylinder. Do injectors some times become loud? Or are my cams slightly out of line with each other causing the chain to ride on the sprocket incorrectly?
