Pintle cap dimension 968?
Installing the injectors but I am unsure as to the correct size of the pintle caps.
I have blue and yellow caps.
Blue are 7.54 mm
Yellow are 6.6 mm.
I found an old green one (5.24 mm) in the box of parts that came with the car.
I have reseal kits from 944 online, but remember hearing that the caps were the wrong size.
Does anyone know the stock size and if you have used either of the 2 mentioned above with no problems.
When I got the car it did not have the injector caps.
Any help is greatly appreciated.
Blue are 7.54 mm
Yellow are 6.6 mm.
