Can the passenger seat be mounted on the driver side?
Hey guys, is it possible to mount a passenger seat on the driver side of the vehicle? I found a sport seat and would like to run a sport driver seat/regular passenger seat. Problem is it's a passenger.
Pros/cons I can think of:
lean forward tab on wrong side
back angle adjustment wheel on wrong side (maybe makes mounting it impossible?)
Slide adjustment handle on wrong side
Questions:
Can any of the aformentioned hardware be easily relocated to the opposite side? I would be reupholstering it anyway to I could get driver side leather if that's possible.
Questions:
Questions:
Questions:
You won't have room for the back angle wheel, as it will interfere with the seatbelt. I was able to remove the plastic portion of the wheel and get enough space for the belt, but it makes adjusting the recline somewhere between difficult and impossible. You can do it to get it right, but don't think you'll be tweaking it on a whim.
The fold-forward tabs are just going to be on the wrong side of the seat. It's manageable, but annoying.
The rails are separate from the seat itself, so the lever to slide the seat fore and aft can be transferred from your existing seat with no issues.
Thanks for the info. Yes mine's an early car. I expected the recliner problem, I can defintely deal with that, just set it and forget it. One other question I just thought of, maybe it's crazy, can the foam of the passenger seat be taken off and put on my driver side frame? is the frame itself different from a sport seat?
I don't think the kind of swap you're talking about is feasible... I'd be willing to believe you could transplant the upper or lower section, but I think most of the structure probably comes from the overall frame than just foam.
