914/914-6 Forum 1969-1976
Porsche 914 - 8 GTT The Build Begins
Old 03-13-2015, 09:01 AM
  #91
Block
2nd Gear
Block's Avatar
Glad I found my way here. Great project!
Old 03-21-2015, 06:12 PM
  #92
Maltese Falcon
Maltese Falcon's Avatar
New "Marty style" rear targa bar latches , no springs.
To be track tested at 185 mph !
Old 03-31-2015, 01:39 AM
  #93
Maltese Falcon
Modified dashboard, just about to go into the upholstery shop.
Just had to keep the Fasten Seat Belt indicator light !
Old 03-31-2015, 01:45 AM
  #94
Maltese Falcon
All of the operations of the car will be Heads-up on this Haltech data logger dash. Indicator to the right is for the gear selector. Sent the entire dash out today for the Alcantara covering.
Old 03-31-2015, 01:51 AM
  #95
Maltese Falcon
Decided to drill and pin additional areas, and add gussets to the trailing arms.
Old 04-04-2015, 02:09 AM
  #96
Maltese Falcon
Alcantara dash was finished up today...
Old 04-09-2015, 05:04 PM
  #97
MATTYLITE
MATTYLITE's Avatar
Hello fellow forum members,
I thought it was time to give you all our April progress update, so let us dive right into it!
We are continuously welding in the roll cage pieces. Here you can see the finishing touches on the cabin to rear pieces.
Next up is the dash. Upon further inspection, we hit a road block when it came to finishing the interior roll cage work because we were unable to fit the dash in after the roll cage would’ve been welded. So, we had to complete the dash in its entirety before we were able to continue the interior cabin roll cage work.
The idea for this dash was literally 3 years in the making and I’m very happy how it turned out. The idea behind the look of it came from GT racing cars, where they use what looks like the OEM dash, but highly modified for the car’s racing needs. We used alcantara and carbon fiber, sourced from a fellow board member. You know who you are! And thank you for helping us achieve such a design masterpiece. There will be a carbon fiber lower dash addition (not pictured) to hold all the switches.
And back from the upholster:
And installed:
FASTEN SEAT BELT!!
The Haltech Engine Management Elite 2500 came in. This supersedes our older Platinum 2000 unit and will offer us more tuning capabilities:
It even comes with a USB Key!
The LED taillights came in from Spoke too!
Once the roll cage work is done, we will be moving on to Air Jack placement :
That’s it for now!
-Matt
Old 04-09-2015, 05:42 PM
  #98
cordsig79
cordsig79's Avatar
wowwwwww
Old 05-19-2015, 10:50 PM
  #99
blue928
blue928's Avatar
Awesome subscribed
Old 05-20-2015, 12:21 AM
  #100
niche
niche's Avatar
I want that dash!
Old 05-20-2015, 03:47 AM
  #101
Maltese Falcon
Continuing with safety cage fabrication:
Right side door impact bars
Old 05-20-2015, 04:04 AM
  #102
Maltese Falcon
Layout of the bracketing for the forward airjack/ kneebar combination; the thin .125 " steel bracket (not used) is what the mfg. supplies...I don't feel good about lifting the car on anything less than a .375" plate steel bracket.
Old 05-20-2015, 04:15 AM
  #103
Maltese Falcon
Welded with sturdy .375" gussets to the kneebar.
The secondary bracket is detachable from the airjack, to allow removal and servicing. All attached with 1/2" grade 8 bolts.
Old 05-20-2015, 04:31 AM
  #104
Maltese Falcon
Top bar of the cage has a small subtle bend on each end, allowing for easy operation of the stock roof latches.
Old 05-22-2015, 02:41 AM
  #105
Maltese Falcon
Right rear Genesis airjack mock-up.
Mfg. the mounting plates + supports in the next few days, then on to the left rear.
Quick Reply: Porsche 914 - 8 GTT The Build Begins
