914/914-6 Forum 1969-1976
Porsche 914 - 8 GTT The Build Begins
Old 08-05-2020, 11:46 AM
  #286
Whitezulu
Whitezulu's Avatar
Originally Posted by Maltese Falcon
Yes we have just completed a short mfg run of 12 sets of these; made from exact assembly jigs sourced from our LM24 hr. #40 car. For exact info on these gt racing headers, contact me at Tech@msdsinc.com and I will set up an order for you.
thanks, i did send you an email, not sure if you received it
cheers
best regards
p.s.: cant wait to see the progress on your 8 GTT
Old 08-06-2020, 04:00 AM
  #287
Maltese Falcon
Maltese Falcon's Avatar
cheers
best regards
These are our fitment and assembly fixtures for the GT racing headers. The specs are indexed directly off of each flange, mandrel bend , collectors, from these patina'd originals; which were on our #40 Sonauto car. The new (copies) production meets my highest QC expectations . More parts arriving for 9148 next week & I'll post up ! I haven't seen your email yet, try this :
msdsinc@sbcglobal.net
Old 08-06-2020, 07:31 AM
  #288
Whitezulu
Whitezulu's Avatar
thanks, i did resend to your other email, i hope you get it
Old 08-07-2020, 01:49 AM
  #289
Maltese Falcon
Custom 300M alloy Sway-A-Way axels arrived today. Going to assemble the cv's and the gooey stuff this weekend ! Their engineers utilize this slight "Bump" in shaft diameter for power of 750+ above. Floating axels measure out at 21 1/16" in length.
Whitezulu (08-07-2020)
Old 09-19-2020, 02:52 PM
  #290
Maltese Falcon
Mounting of the SQS shift mechanism, and related circuit wiring
Old 09-19-2020, 03:47 PM
  #291
Maltese Falcon
We had a custom length cable made for the SQS, it's approx 100" in length; required due to mid engine (rear trans) use. SQS normally made for the late rear engined 911 series...which places the trans closer to the cockpit
Old 09-19-2020, 03:49 PM
  #292
Maltese Falcon
...also using Goodridge fire-sleeve for added heat protection of the shift cable
Old 09-20-2020, 03:45 PM
  #293
Maltese Falcon
Performance4Plastic Left snd Right plexi slider windows just arrived from the UK
mlmgm (09-20-2020)
Old 09-24-2020, 01:29 PM
  #294
Maltese Falcon
New SQS module + 6 gang fusebox fits nicely here
Old 10-10-2020, 06:59 PM
  #295
Maltese Falcon
...closer look at the SQS sequential shift mechanism
Old 10-10-2020, 07:06 PM
  #296
Maltese Falcon
SQS Attached to the gt2 transaxle , the gearbox is then installed Inverted in the chassis (for mid-engine use),
due to the ring gear not being able to be physically flipped internally in the gearbox.
cjcam930 (10-11-2020)
Old 10-10-2020, 07:10 PM
  #297
Maltese Falcon
We will be using this GlowShift brand dual range EGT pyrometer: allowing for exhaust temp monitoring of both left and right bank exhaust headers
Old 10-12-2020, 10:41 PM
  #298
Maltese Falcon
Heat shrink insulation supply is strong
Old 10-12-2020, 10:43 PM
  #299
Maltese Falcon
Almost time for test-shifting the SQS...
Old 10-17-2020, 01:41 AM
  #300
Maltese Falcon
Houston "We have gears"
Quick Reply: Porsche 914 - 8 GTT The Build Begins
