Porsche 914 - 8 GTT The Build Begins
#171
Marty every time you share these updates it reminds me to get over there and check out your shop and projects in person sometime soon!
#173
Hey Marty,
Any estimate as to when you will start tuning on this? I am real curious as to how it runs. I saw yours over @ Lozano's before they shipped it to you. I think you were around 8:1 compression, but with cams and the elim. of the. variocam. I too have a Lozano built 4.5. Getting my ecu prepped now and ready to start tuning in the next few weeks. A bit different than yours but shooting for the same power goals in a Cayenne. Using Borg Warner EFR 7163 Aluminum supercore Turbo's on 9.5:1 and e-85.
#174
The transaxle support beam is now fastened down to the chassis... So ; now doubling as the Rear wing Left and Right wing strut mount points . Strut des
ign in progress.
J'sWorld...not sure about the tuning on your ECU; ours is a Haltech Elite 2500. It will eventually be tuned at a Haltech tuner in Lake Havasu, Az.
Did you retain the OE Cayenne oil pan ¿ Ben, Mike and the Lozano crew are amazing
#176
@ Marty,
Too many networked systems in the Cayenne for standalone on my budget right now....However the Bosch is just as capable in the right hands. I am using the stock pan and oiling system. It is one of the best I have ever seen on a normal factory vehicle and no clearance considerations for the Cayenne. Your build is ridiculous! Top notch! If you can make it hook.......waaahhhh!
Ben and the crew are really great people. I couldn't be happier with how my engine runs. The ring seal.... no smoke, no slap. Look familiar? The two engines from the Action Express car. Not sure which one won the race.
#177
@ Marty,
End of the day....Ben said that the Cayenne v8s are as tough as they come, even more reliable than the LS gm v8s of that era . Ben showed us their Daytona 24 hr 2010 trophy...and then he recanted the short speech he gave in winners circle that day; if you've never heard it It's a Hoot !
#178
Wing supports are popping out of the unibody nicely . These will serve as the foundation point for the Left and Right uprights that support the roof-high carbon fiber wing
