Going crazy with the door seals!
Namely the window seals for the main glass in each door.
Several questions:
Are there two squeegees on each door or just one on the outside?
There are two fuzzys on each door and one is screwed to the door with a metal strip? The one without screws is the innermost seal?
How does the squeegee stay on the door?
Thanks much,
Christoph
Several questions:
Thanks much,
Christoph
Rennlist Hoonigan
which cost no drachmas
One squegee on teh outside slides into a channel. It's a pita.I think their is a felt on the inside and out, screwed to a metal piece or attached to a metal peice and screwed to the door. Check the pet if you don't have a car handy.
Aha! I have a door. What a PITA that is to put together. The outer fuzzy is apparently NLA. So I bought one from a 911. It's a little wider but it works into the channel with some modification.
