1975 2.0 wiring help/question
I had the fuel pump relay burning up on the #86, I traced this under the engine fuse block to the wiring plug that plugs in just below the relay, the number #86 from the relay runs into the Number #19 white wire from the plug, NOW I traced this all the way back to the ECU, soooo it looks like the ECU is grounding out some where on the inside? If I unplug the wiring to the ECU the ground goes away? anyway, when I bought the car the owner had to hot wire the same relay to get the car to run, so I guess I need a rebuilt ECU? any thoughts, and I know I confused a lot of you, I might need to include pics, thanks Jeff
