New 914 owner here!
Originally Posted by Martin Baker
I am near by if you would like an evaluation on the car. I have owned 10 914 types, currently own 4. I have a good knowledge base, and could help steer you in the right direction. We also have a monthly 914 gathering at RPM on Brashaw, the indoor KART track.
Martin
Martin
We dont know much about the 914 itself though, so if you could drop by and give us some hints, that'd be great
Let me know when you have time, this weekend is full but next weekend the car should be up on our rack and it'd be easier for you to tell us if there's anything that would need work or replaced.
Our shop is on waterman rd right next to radial tire.
http://thetruckshoppe.com/
By the way, how well do the carb setups work on the 914 2.0 liter? Id like to go that route with it because its pre smog and the prices on fuel injection parts is just insane. Its almost worse than my 944!
Where could I pick up a carb system from? Is there any good performance places online for 914's?
Originally Posted by future
Ebay's your best bet for the Haynes Manual on the cheap
Nice car... I'm Just in the process of looking for one myself. Decided on a 2.0 it's just a case of finding the right one.
Your car would look better if you color coded the silles and rear bumper but a nice find all the same.
So what are your plans for it
The car is a '75 according to the pic you posted of the serial no. I believe you will have to smog it. Mine is a '74 and is smog-free. If you have to smog it carbs will be a big no-no.
I also live in Elk Grove. If you have seen a white 914 cuising around town it may have been me.
I think I may have seen you around before
Im always in my 944, were you over by EG blvd by the carwash a few months ago driving through the neighborhood?
It is fairly likely it was me. I haven't seen any other white 914s in Elk Grove for quite a long time now (though there may still be a creamsicle in the area behind Taco Bell off of EG Blvd). If I see a red 944 I'll wave.
Dual carbs subtract hp not add as the stock cam is set up for FI not carbs. If you are going to take the engine apart and keep the FI (wise choice) you can run the Raby 9550 cam and really wake up the engine and keep the killer torque that FI gives you,
What heat exchanges are on it? early of late style? you can find the Stainless steel early ones and gain about 8hp installing those instead of the late ones.
Nate,
I didn't realize you were in the Elk Grove area. I live off of Bond near 99.
Apex944,
I have seen a redd 944 around many times, probably you? What area do you live in?
Apex944,
Unfortunately we will have to sell the 914 soon, we cant keep it. We will repair everything that's wrong with it then sell it of course, and give it a tune up.
I would like to get one sometime later on so im not totally leaving the 914 world, just temporarily
I live off Bond and Bradshaw, diagonal from that new pleasant grove high school.
By the way, is there a big upside to having a side shifter trans in the 914?
And a friend of mine down in arizona used to have one, and he was saying to ask about the "hell holes". What are the hell holes?
The hell hole is a common rust area that is just forward of the battery tray.
Here is my new toy as of last Thursday. Got a fairly nice 74 2.0, and after a couple of hours with Martin (Thanks!!! ) It ran much better!
Originally Posted by Jay Gratton
OK, the other Limited Edition car is white and orange. Also, that car was made in November of '74 and has a late model rear bumper on it (75 & 76) so I am guess it is a '75 model year. 914's are great cars once you work the bugs out of them. I would make sure the car is solid in the rockers and such before I started dumping money into it. Good luck!
Apex-
Saw your car at the shop about a month ago- met with the front desk guy as your dad was out making a road call- left my card. Did you guys ever end up getting rid of it?
Nate
Nate
